dermotM
If input Hub 3 into modem mode do I lose firewall
I’ve added a Linksys Velop system to my home and at the moment I have connected it to one of the Hub 3 Ethernet ports. So currently two networks in parallel with the Velop mesh network having double Nat. I was wanting to turn off the Virginn Wi-Fi network and use the Hub 3 in modem mode and thus get rid of the double Nat issue. However I am concerned that the Velop Router doesn’t implement any Firewall functionality. If I place the Hub3 in model mode does that mean I lose the Hub 3 Firewall. If so does anyone know how to overcome that. I have seen some posts that indicate people have implemented the Velop Mesh network by putting the Hub3 in modem mode. How have they maintained security if the Hub 3 in modem mode turns off its firewall functionality
tehwolf
  • 1.52K
  • 243
  • 367
Superfast
Re: If input Hub 3 into modem mode do I lose firewall
Yes, the hub would no longer provide any sort of firewall in modem mode - it passes that responsibility on to whatever router you're using.. in your case, the velop primary node effectively becomes the NAT device / firewall for the entire network..
  • 15.4K
  • 659
  • 1.51K
The hubs firewall was unless anyway.
Linksys Velop will do NAT that acks like a firewall anyway.
