on 04-11-2023 18:15
So, just logged into router to check devices and whats connected and whatnot and I see this
What is with the /24?
04-11-2023 18:56 - edited 04-11-2023 18:58
/24 means there are 256 IP addresses in the IP range.
looks fine?
/24 is the subnet 255.255.255.0 that your LAN is in so range 192.168.0.1 - 192.168.0.254
on 04-11-2023 19:22
Never seen it before, it always ended before the /24, why confuse people?
on 04-11-2023 19:27
It's only confusing if you don't know what it means.
Maybe a firmware update?
on 04-11-2023 19:46
apparently software update on 18th october, still didnt fix error reporting for pre/post rss errors though and upstream t3 timeouts
on 04-11-2023 19:53
@alphaomega16 wrote:apparently software update on 18th october, still didnt fix error reporting for pre/post rss errors though and upstream t3 timeouts
Those errors are generally related to line issues or a faultly HUB, not firmware.
12-11-2023 23:17 - edited 12-11-2023 23:18
Yes but an update stopped them being logged before when I was having a lot of troubles, even now you can see T3 timeouts in the network log which relate to upload but all the entries in upload show 0 for errors that is how you know its still borked.
When I was having trouble before and even when ive had massive packet loss on the line due to issues in my area all the pre and post errors were 0 whilst neighbor who is on hub 3 had thousands of them.
I am not the only one encounter this.
on 15-11-2023 09:07
Hi alphaomega16,
Thank you for reaching back out, if you are still facing issues with this we will need to run further checks and if required look at sending a technician for further investigation, so I can do this I will send you an invite into a private chat, once received click on the white envelope to accept.
Paul.
