on 13-06-2023 00:27
I do not need Wifi 6 and I was very happy with the Hub 3
I do not need a landline.
I was upgraded to the I Gb service with a new contract on 01/06/23 and the hub 5 performance is awful.
260 Mb/s max and sometimes 45 Mb/s ......On 1 GB Ethernet
My 2 Tivos work fine
The telephone will dial out but does not ring.
I was only going to use it for incoming calls........
I use Vonage VOIP for outgoing calls
I have had many unfruitful calls to customer service and I am seriously thinking of leaving Virgin after 28 years of contentment..........
Here is my latest email to the vm team.........
on 13-06-2023 01:14
on 13-06-2023 20:34
Update on Yesterday's Post
today.......HAPPY DAYS but first
My shiny new unreliable Hub 5 crashed six times in 2 hours........
And then.......
I spoke to a very helpful agent in India called ROHAN,
He really is a very very capable agent.
He downgraded my 1 gig package to VM600 which IS what I had been told by the sales agent is no longer available !!
ie back to the services I had before.....for less money.......................HOORAY
He then reactivated my Hub 3 for 600 Mb/s and enabled the telephone which again would dial out but not ring on incoming calls.
He did notice some stability problems and suggested I use https://samknows.com/realspeed to run tests.
He did try and call me and the cv21 phone did not ring....
As arranged he then called me on my mobile to continue the conversation
He booked me an engineer for Monday (my first available day)
He said he will call me after Monday to check progreess.
And finally............
I have MANAGED to enable the phone to ring by simply plugging it through an ADSL adapter (from history)
plugged into the supplied virgin adapter and the capacitor in the adsl adapter does the trick !!!!!!
I had found a post suggesting DECT phones would ring and then I found a link
Virgin Hub 3,4 or 5 Telephone Adaptor RJ11 Plug - BT Socket with Ring Capacitor eBay
and then I found Community posts explaining that CV21 hubs do not contain ring capacitors
QUOTE....
IRC only a BT master socket and some DSL filters have ring caps, most other things won't. I know the hub or the adapter VM provide do not.
Quote
The Hub itself does not have the Ring Capacitor built in, this is all done through the adapter that you have received. The RJ11 Adapter that you have received for your migration will only be usable in the back of your Hub in the Phone port.
The last post is in error as mentioned in the first...the standard VM adapter will not work with stardard BT type phones
The Hub phone system is NOT VOIP it is CV21 where the phone signal is modulating a carrier which returns to Virgin exchanges using the DOCSIS and fibre.
I feel all these facts are VERY IMPORTANT especially for septo pensioners like myself who DO NOT NEED TO BUY A NEW PHONE SYSTEM to work with the CV21 based hubs !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
That adapter is priced at £2.50 and ADSL adapters will soon be thrown away by the masses....as fibre triumphs over copper.
I AM A VERY HAPPY MAN TO BE ABLE TO STAY WITH VIRGIN !!!!!!!!
Thanks ROHAN and community members who have analysed the problem.....
many many thanks...I hope this post helps stop the confusion over CV21 phone systems.
soundcomputing
on 13-06-2023 20:43
Great post and well done Rohan. I hope the VM forum team can pass on the great feedback.
on 14-06-2023 00:02
Someone's grumpy.
on 27-06-2023 11:35
Hi Cardiffman282
Thanks for the appreciation of my post...........
After the visit last Monday ( 19th ) all seems to be AOK rather than the TAFUBAR it was before I spoke to Rohan.
The engineer was very very good and finally afer swapping out a very old Telewest splitter he was then able to decide that there was a intermittent cable fault in the link ( app 3 ft length ) from that to the hub ...but nothing visible like a mouse bite etc.
He fitted a new link with obviously a new connector into the hub and so far I have not had any problems and Real Speed is consistantly reporting DL of 650 Mb/s and UL of better than 40 Mb/s Tivo to Tivo links are great AND
My CV21 phone works well and RINGS ........
And the engineer later rang back to check.......on performance ....using the CV21 line.
Ryan confirmed that VM do not carry Adapters with ring caps..... he was also very happy with the work his younger brother Liam had done on the previous visit.
So I am Happy
Thanks to ROHAN and ALDANE ( THe first Engineer who tried to get me on CV21 ) and LIAM and finally RYAN.
ie The people who Know their Jobs do care !!!!!!!
soundcomputing
on 29-02-2024 17:00
Yesterday I tried to downgrade mine, from 1 Gig to 500 or 360 and it was more expensive as I would lose a £30 discount I get on my complete package that includes 1 Gig. Crazy.
