on 03-07-2022 09:14
Installed new hub5 with WiFi 6 yesterday. All devices ok except Samsung galaxy s20 which does not connect to WiFi, either manually or via qr code. All other devices that connected to previous hub are working fine, including iPhone, galaxy s22 ultra and galaxy tab. Any ideas?
on 05-07-2022 14:21
Hi awthomson,
Thanks for your post and welcome to the forums. It's great having you on board with us in the Community.
I'm sorry to hear you're having an issue connecting your Samsung S20 device to your WiFi.
When searching for the network in the settings, are you finding it? If so what happens when you try to join it? Does it gie you the option of entering in the passphrase?
Pop back and let us know.
on 05-07-2022 14:37
Yes, finds the SSID, and lets me enter password, but still doesn't work.
I must reiterate this device worked perfectly well on the previous router which we had last week before this new one was installed.
on 05-07-2022 16:09
Try setting the 2.4Ghz band to a legacy setting as below:
Access your Hub by navigating to 192.168.0.1
Login with the default login info (on base of Hub) unless you've already updated it.
Go to Advanced Settings > Wireless > Wireless signal
In the Wireless frequency 2.4GHz select Wireless mode > 802.11b/g/n/ax mixed
Select Apply changes
It may be your s20 does not like the ax wifi 6 protocol ?
on 05-07-2022 16:11
Will give that a try and let you know
on 07-07-2022 16:32
Tried that, it knocked all devices off the internet so changed settings back
on 07-07-2022 17:35
Thank you for the update @awthomson.
Is this the only device you are having issues with? Also, are you able to check that airplane and offline modes are deactivated on your device? Have you also tried rebooting your device to see if the issue persists?
on 07-07-2022 17:38
Airplane mode not on. Like I said, all other devices worked before and after hub replacement- xbox, androids, ipad, iPhone, firestick, TV- just this one device that doesn't connect.
on 09-07-2022 17:48
Hi awthomson,
Thanks for coming back to us - has this worked since posting? If not, can the device see the broadband and just not connect, or not pick it up at all?
Best,
on 09-07-2022 18:06
It finds the wifi ssid, I enter the password, it tries several times saying "connecting", then eventually fails stating "connection failed". I haven't changed any settings on the hub, and apart from this phone every device that worked on the old hub works on the new one. It's the only Samsung galaxy s20 in the house.
