Hub5 and Norton Secure VPN
Chris016
Since installing the new hub my secure vpn will not connect.
any advice please
1 ACCEPTED SOLUTION
Accepted Solutions
Login to the Virgin Media online account and check the Web Safe settings.
VPN operates fine for use with :
Virus Safe : Enabled
Child Safe: Disabled -  When Enabled this settings blocks VPNs / Teleconfs / Messenger Apps via DNS redirection
7 REPLIES 7
You need to use hub in modem mode and get your own router with 1Gb ports
Thanks but no good. Any other thoughts?
Sephiroth
Have you got the pass through settings enabled?
Change to another ISP if you don't like my answer
Not sure how/where?
For some customers the VM settings for Child Safe can be set to OFF but continue to remain Enabled.
Check if this is the case, can you access the websites of Ladbrooks and Beretta ?
If not try changing the computer to use a Public DNS like Google DNS 8.8.8.8 & 8.8.4.4
