GH5
  • 8
Message 1 of 19
Hub5 affecting BOSE smart speaker
Hi.  Since installing Hub 5, my BOSE smart speaker has lost some functionality.  BOSE have advised it's a security setting on the router and have emailed me the solution to forward on to Virgin but Virgin steadfastly refuse to take receipt of this email and make the changes to the security settings.  Any ideas what I ought to do next?
Thanks.
G.
japitts
  • 19.18K
  • 2.48K
  • 4.39K
Message 2 of 19
Re: Hub5 affecting BOSE smart speaker
What functionality is it that you've lost?
And what's the suggested fix?
GH5
  • 8
Message 3 of 19
Alexa and Air Play won’t work but connecting my iPhone using Bluetooth does.
jem101
  • 4.21K
  • 432
  • 1.8K
Community elder
Message 4 of 19
But what exactly did BOSE send to you to forward to VM? If you post it up here (after having taken out any personal information, email addresses etc), we can take a look and see if it makes any sense.
GH5
  • 8
Message 5 of 19
Hi - Email from BOSE below...
Hello,
Please sent this to Virgin media, They will understand what it means as they will need to use port forwarding.
Bose systems on your network use the following ports:
Port
Type
Service or Protocol
Used By
80
TCP
Hypertext Transfer Protocol (HTTP)
AirPlay, SoundTouch / Bose Music
123
UDP
Network Time Protocol (NTP)
443
TCP
Secure Sockets Layer (SSL, or "HTTPS")
AirPlay
554
TCP/UDP
Real-Time Streaming Protocol
1900
UDP
Simple Service Discovery Protocol (SSDP)
Bonjour
3689
TCP
Digital Audio Access Protocol (DAAP)
AirPlay
5350
UDP
NAT Port Mapping Protocol Announcements
Bonjour
5351
UDP
Bonjour
5353
UDP
Multicast DNS (MDNS)
Bonjour, AirPlay
8080 - 8085 (PC)
8085 - 8089 (Mac)
TCP/UDP
HTTP, DLNA
8090
TCP
HTTP
8200
TCP
Media server
Spotify
8883
MQTT
Remote connections
Alexa Skill
17008
TCP
Bose Proprietary
Bonjour, SoundTouch / Bose Music
Kind regards
removed
Bose Technical Support
gary_dexter
  • 32.63K
  • 2.02K
  • 4.47K
Message 6 of 19
Those are firewall/port forwarding rules. They’ll likely be unnecessary to actually implement.
The issue here likely lies with the hub5’s unstable Wifi for non-WIFI6 devices.
GH5
  • 8
Message 7 of 19
Thanks.  I'm not a teckie person by any manner of means so it's all double dutch to me I'm afraid.
All I know is BOSE told me they were aware of the issue (as it'd been reported to them by others in a similar position) and that the fix they've emailed me would sort the problem.
The issue I have with Virgin is they won't look at the email BOSE have sent me.  They even tried to get me to subscribe to their Gadget Rescue service rather than just at least look at the fix BOSE have sent me.  Even if they looked at and advised it wasn't a help that'd be fair enough.
The Virgin complaints procedure is laughable as well as all it does is refer me to the same people I have the complaint with.  A bit like going to the police after a burglary and the police tell you to take it up with the burglar!
gary_dexter
  • 32.63K
  • 2.02K
  • 4.47K
Message 8 of 19
You need to split the Wifi bands (by naming them something different) and then try connecting the Bose to the 2.4ghz broadcast.
GH5
  • 8
Message 9 of 19
Looks like it's already on 2.4ghz.  Worth a try though. Thanks.
jem101
  • 4.21K
  • 432
  • 1.8K
Community elder
Message 10 of 19
@GH5 actually what BOSE technical support sent you is all a bit pointless really, and saying that VM technical support would understand it and know what to do is a bit of buck-passing of the highest order.
Truth is this, presumably your system worked perfectly with the previous Hub, yes? So the issue will be in the different way that the Hub 5 handles WiFi, evidently there is some fundamental issue between it and the BOSE system, and, frankly, knowing how these things pan out, each will blame the other and throw it back on you to sort out.
OK here’s what you do, contact VM and say that the supplied Hub 5 isn’t working and demand that you revert back to the 3 or whatever you had before. They’ll probably argue or want to send an engineer out, you might want to disconnect the hub before you call in and that way they can’t say they have connected to it OK, checked and everything is fine - well actually they might say that, but at least you will know they are lying through their teeth!
