Sign in
Sign out
2 weeks ago
I can’t get the virgin connect to connect with my hub 4
It’s a bit flakey. Keep trying for a few days. Make sure you are on the VM WiFi and not using a VPN.
Hi deano475,
Thank you for your post and welcome to the community.
I'm very sorry for any issue you're having with your Virgin Media Connect App.
What error message are you getting on the app when you try to connect?
^Martin
Monday
HUD not found they should ask sky tv there hub security is the best
Wednesday
Hi deano475
Thanks for coming back to the thread. You're not using a VPN or got any anti-malware software on the device have you?
Best wishes.
