  • 10
Message 1 of 18
Hub4
I took delivery of the Hub4 yesterday and set it up as my previous settings.
Unfortunately my Wiser heat hub doesn’t connect to the internet, it connects by WiFi and is visible on the hub when you log in.
I’ve just spent 5hrs being connected and disconnected to the fault team and taken out a contract with the Virgin 3rd party fault team and still it won’t connect, meaning I can’t log into my heating using the App which is the only way of controlling it.
My Philips Hue also connects by WiFi and is working as are my Amazon products but not my heating hub.
I would be happy to use the hub I had but that’s now been blocked.
  • 24.72K
  • 1.43K
  • 3.15K
Message 2 of 18
Re: Hub4
Have you separated the WiFi bands?
  • 10
Message 3 of 18
Re: Hub4
Yes, I’ve turned off the 5Ghz and only using the 2.4
Thanks for that anyway 👍
  • 24.72K
  • 1.43K
  • 3.15K
Message 4 of 18
Re: Hub4
Have you changed the 2.4Ghz band to b/g/n?
  • 10
Message 5 of 18
Re: Hub4
No I haven’t, I’ll do it now and try it 👍
  • 10
Message 6 of 18
Re: Hub4
Just changed it and it failed
I’ve also changed the channels 1,6, and 11
I’ve set it to auto and all have failed!!!
  • 24.72K
  • 1.43K
  • 3.15K
Message 7 of 18
Re: Hub4
Put the hub into modem mode and attach your own (better) router or mesh system.
  • 10
Message 8 of 18
Re: Hub4
Thanks for your help and suggestions, it’s confirmed what I have been doing was correct but to no avail.
Hopefully I’ll get to the bottom of it soon.
  • 10
Message 9 of 18
Re: Hub4
I did a diagnostic test when I noticed it had problems and put the multiple WiFi problems it reported, down to me changing some settings.
Today I thought I’d make sure that was the case.
I have done a factory reset and all that is connected is my iPhone and guess what? It’s reporting multiple WiFi problems!!!
  • 24.72K
  • 1.43K
  • 3.15K
Message 10 of 18
Re: Hub4
Because it’s not intelligent at all. Ignore the diagnostics and just get your own better kit as advised above.
