Hub4
Hi just a quick question unsure of the answer.
Does the hub4 have to run on the docsis 3.1 network rather than the 3.0?as I am on M100 with a hub4 and the speeds I am getting are terrible. And my area is docsis 3.0.
Anyone know if it would make a difference ?
Tags (3)
  • 1.32K
  • 190
  • 629
Re: Hub4
The answer is no, DOCSIS modems are downwards compatible from 3.1 to 3. So using a Hub 4 will not be any better or worse than a 3 in your situation. Bets post up the specs from the modems logs and we can see if anything jumps out.
