Bencaw90
  • 36
Message 1 of 9
Hub4 reset
Hopefully someone will know, we are having an issue every evening devices such as mobiles, tablets etc will loose connection, other things like laptops and desktop pc are connected perfectly fine, someone mentioned logging into the hub an setting up the 5G setting however I cannot log into the hub nor could the engineer as it says the password is incorrect, we have been told to reset the hub at the back with a pin, but wondering if we will have to manually connect everything again such as the Sky Q boxes, mini boxes, Alexa, tablets and devices? Or if these will remain after the reset, we are hoping for the hub password to work after doing so?
  • 33.49K
  • 3.29K
  • 6.36K
Message 2 of 9
Re: Hub4 reset
Do as reset as below.
First, make sure the 2 passwords on the Hub sticker are still there and legible first ! Disconnect any ethernet cables from the Hub (leave the coax connected), and then with the Hub still "switched on" throughout, press pin in firmly to the "stop point" with paper clip/SIM tray tool or similar "thin thing" and hold it firmly for at least 60 seconds, release the pin, leave for 5’ to stabilise - dont manually switch the Hub off at any time. Leave it 5' to re-initialise - both Passwords will reset to those on the sticker.
Then... log into the Hub and rename the SSID and password to those you were using before (if they were different to the sticker ones) and the other devices should be fine
Martin_N
  • 8.29K
  • 351
  • 508
Message 3 of 9
Re: Hub4 reset
Hi Bencaw90,
Thank you for your post. I'm very sorry to hear about the issue you're having with your hub 4.
Have you been able to try the suggestion by jbrennand?
I have located your account and checked out your levels and am unable to see anything that could be affecting this.
^Martin
Bencaw90
  • 36
Message 4 of 9
Re: Hub4 reset
Hey,
Sorry not at the moment just in the office so not bad chance to do this yet will get this sorted asap and will post the information
Cheers
Ashleigh_C
  • 4.09K
  • 162
  • 310
Message 5 of 9
Re: Hub4 reset
Hi there @Bencaw90
I just wanted to check in as it has been a few days since your last post.
Have you been able to do this now and has it helped the issues?
Thank you.
Ash_C
Bencaw90
  • 36
Message 6 of 9
Re: Hub4 reset
Hi, it wouldn’t let me copy and paste I did write a message with the images but looks like they have been deleted, won’t allow to to paste as all so guess no one gonna be able to help if we cannot post them here
Hayley_S
  • 3.9K
  • 129
  • 255
Message 7 of 9
Re: Hub4 reset
Hello @Bencaw90,
Your up and down streams are looking healthy on our systems, have you ever set up a BMQ chart before?
Many thanks,
Hayley
Bencaw90
  • 36
Message 8 of 9
Re: Hub4 reset
Yeah I did set one up and posted the pictures however they were taken down, to be honest since I disabled the auto channel change it’s been perfect, not lost connection once touch wood
Kath_F
  • 33.66K
  • 1.29K
  • 2.72K
Message 9 of 9
Re: Hub4 reset
Hi Bencaw90,
Thanks for taking the time to come back to us and update the thread.
We're really glad to hear that things are working for you now and the connection has stabilised.
If you have any further issues, please pop back here and let us know.
Kath_F
