derek765
  • 27
Message 1 of 5
Hub4 power - UPS ?
Shortly having some electrical work done at my house, so the power will be on and off repeatedly for a couple of days.
Is there a (type of?) UPS device I could install to protect against the router going offline - say an hour or two of backup ? Second question - is Hub5 the same power connection, ie would any UPS I get for the 4 still work with the 5 when I get one ?
Many thanks
Tags (4)
jpeg1
  • 7.55K
  • 390
  • 1.48K
Message 2 of 5
Re: Hub4 power - UPS ?
Yes there are plenty of small UPS that will keep the Hub going for a few hours.  Amazon lists several.  You need one with ac mains output so that any Hub with its own psu can plug into it.
goslow
  • 5.48K
  • 739
  • 1.98K
Superstar
Message 3 of 5
Many thanks
Assuming you will still have power to the supplier's cutout fuse in your home during the work, ask your electrician to wire up a temporary board for you while the electrical work is taking place (to run things like your fridge, router etc.). That should be a common request for most electricians now with so many people working from home.
A simple domestic UPS generally won't keep equipment running for that long. It is designed for short power cuts (minutes in length) until the power comes back on.
Portable 'power bank' type devices are also quite common now, and are designed to run for longer, but are pretty expensive for what they are. Your electrician may possibly have one for customers to use when the power is off.
Are you looking for a solution just for the period of the planned electrical work or are you thinking of power backup for use in the longer term?
  • 1.92K
  • 123
  • 444
Super solver
Message 4 of 5
Have a look at APC UPS for some typical examples.
Hubs 4 & 5 both have PSUs with a 13a plug - if yours is an RFoG area then that will need a second 13a socket.
  • 20.48K
  • 828
  • 2.2K
Message 5 of 5
