Hub4 needs rebooted often
Hi.. New hub 4 installed last week first few days were fine but for the past few days it's been disconnecting at least twice daily and needs rebooted to kick back into action.
Speeds are great but the disconnection issue is a major issue.. It disconnects from both wired  connections and WiFi..
My old hub 3 was fine with 500mbs and didn't have these issues. Any suggestions or fixes?
Tags (1)
  • 24.64K
  • 1.42K
  • 3.14K
Re: Hub4 needs rebooted often
Post the network, upstream and downstream logs from the hubs admin page
  • 11.73K
  • 915
  • 1.51K
What is your contracted speed ?
Mike Robinson
