on 01-12-2021 13:46
Hi. I' had been running with a Hub3 for around a year with zero issues. I recently was given an "upgrade" to a Hub4.
I'm getting issues where some devices lose their connection to the internet (not to the hub). Usually when watching eg sport on NowTV it will just stop. Other devices will still be working fine and connecting to the internet. This happens if the TV is connected via WiFi or ethernet. If it stops while using WiFi I can switch to ethernet to resume the streaming(and vice versa).
This is extremely irritating.
Any ideas or help will be appreciated. I really wish I hadn't sent the Hub3 back
on 01-12-2021 13:55
on 01-12-2021 13:59
Why would that help as the issue occurs with both wireless and ethernet connections?
on 01-12-2021 14:02
on 01-12-2021 17:26
Not much consolation, but I have exactly the same problem. Both wired and wireless connections drop randomly. I've tried all the fixes, switching off Smart WiFi, adjusted settings, etc none of which have helped.
There is obviously a fundamental issue with the Hub 4 which needs to be addressed quickly, or, VM need to give us back the Hub 3 we returned.
on 05-12-2021 11:57
Hi @PeteGR thanks for posting and welcome to our community.
Sorry to hear that your hub 4 is losing connection to some of your devices. I have located your account. I am going to send you a private message.
Lee_R
