Message 1 of 5
Hub4 hotspots
Hi,  I've just "upgraded" to a hub 4 and now can't access hotspots or use the connec
t app, which is showing as incompatible
Is there going to be a new app available in the near future.
Has the new hub got anything to do with me not being able to connect to hotspots.
Any advice would be greatly appreciated
Dave
Tags (1)
  • 21.1K
  • 2.27K
  • 4.2K
Message 2 of 5
Re: Hub4 hotspots
Being able to access the hotspots away from home has nothing to do with which Hub you have, so it shouldn't make any difference.
Saying that the Hub 4 doesn't currently generate a hotspot itself. It's also not currently compatible with the Hub management bits of the Connect app.
  • 24.77K
  • 1.43K
  • 3.15K
Message 3 of 5
Re: Hub4 hotspots
The hub4 in itself isn’t a hotspot router.
You should still be able to access hot posts out and about regardless of what the hub is.
  • 14.76K
  • 620
  • 1.42K
Message 4 of 5
Re: Hub4 hotspots
Unless you happen to be the hotpot that was the hub 3 and wanted to connect to and now with the hub 4 you can't.
  • 21.1K
  • 2.27K
  • 4.2K
Message 5 of 5
Re: Hub4 hotspots
Why would you need to connect to the public hotspot in your own home? If you have a Hub you can use the private WiFi
Public Hub hotspot coverage isn't guaranteed as people may opt out or move providers.
