  • 209
  • 14
Dialled in
Hub4 dropping wifi to samsung tab
I took the free upgrade/downgrade to the hub4 and seem to have an issue in which wifi drops to a samsung tab A 10.1 2019. It shows as connected but no internet. You have to turn off the wifi and turn it back on (on the tablet).
I had a simililar issue on the hub3 when trialling that smart wifi stuff but happened to a few more devices (most no longer used now)
Is this a known issue that will be patched at some point? I know other people locally that took the upgrade and had the same issue.
I've seperated the wifi bands to see if that will help for now.
  • 24.48K
  • 1.4K
  • 3.11K
Re: Hub4 dropping wifi to samsung tab
See if the band separation helps first
