Hub4 download speed
Good evening I've just installed my new hub4 router I'm on a 350mb package and I'm getting mixed download speed using speedtest.net. My iPhone is recording 380mb which is great. But my android phone and my Windows laptop are struggling to get 100 mb download. Anyone know the reason for this and what I can do. Many thanks
  • 2.29K
  • 168
  • 303
Superfast
Re: Hub4 download speed
If you access your HUB on http://192.168.0.1, log in and access the 'Connected Devices' section what speed do your devices show as connected at?
This will give a 'rough' idea why some devices are slower than others.
  • 14.31K
  • 592
  • 1.37K
Getting 100Mb by wifi is fine as wifi is not that great for speed use a wired connection on a 1Gb link.
If you think you can get better speed by wifi then thats down to you with a wireless router with 1Gb ports and the hub in modem mode.
