Hub4 disconnecting from sky Q box
Recently received the new hub4 & everything connects fine apart from the sky Q box which constantly disconnects from the wi-fi leaving us with no tv upstairs,rang virgin approx 9 times with promises of tech support ring back with no one ever calling,it further does'nt help that the app is not even upgraded to even test the hub4....getting very frustrated🤬🤬
  • 11.56K
  • 823
  • 1.64K
Re: Hub4 disconnecting from sky Q box
Of the sky Q keeps loosing wifi you might have to buy a set of powerlines to wire it in instead
I work for Virgin Media and my posts are my own opinions
Never had any problems with the Hub3 only now with tge Hub4 seems not compatible with the sky q box,cant hard wire as all wires are built into the wall.
  • 24.46K
  • 1.4K
  • 3.11K
Reset the network settings on the SkyQ boxes and rejoin them again
