Hi, I have a new Smart Thermostat that will only connect to 2.4GHZ wifi frequency but note the Virgin Hub 4 automatically uses both 2.4GHz and 5GHz so will the smart thermostat work?
Can I change settings on Hub4 to force the connection to 2.4GHz and if I do that will it effect the coverage of the wifi in home. We are also using a virgin intelligent booster pod.
The smart wifi thermostat is Meross MTS200.
Any help appreciated. Thank you
