Is there a way to unlock the DNS settings on the Hub4, so I can change them?
Is there another router that Virgin provides that would allow this?
I recently upgraded from the Hub2 to the Hub4. The Hub2 worked fine in modem mode and I used an Asus router with it. However, the Hub4 in modem mode appeared incompatible with my router, so I have had to mothball the router and use the Hub4 in router mode. Unfortunately, the Hub4 does not allow me to change the DNS settings, so I can't use a a web filtering service for all connected devices. I don't think it's worth trying to put the Hub4 back to modem mode, because it doesn't seem to work properly with my router, from experience.
