Hello
Has anyone seen issues with Hub4 refusing to allocate DHCP addresses? Specifically I have an issue with NVIDIA shield not connecting. It did momentarily but then disappears. I have allocated fixed IP addresses for a number of devices in order for my NAS drive to be able to control access with some higher degree of certainty, e.g. so I don't let the wifi enabled lightbulbs IP address access to my NAS. No I don't wear a tin-foil hat but... well.
But regardless, all wifi devices in the house have worked.
If it is relevant I also saw that when I was trying to name those devices in the superhub "Home" page that it gets in a right pickle and starts overwriting device names left right and centre. And as I renamed each device to their proper name the NVIDIASHIELD seemed to be the name that kept getting passed around the various devices.
But since then I've both restarted the Hub and factory-reset. Since then all my devices in the house connected fine. But the shield will not connect. FYI I've not updated shield to the FW released yesterday so it's not that. Also I had both Subperhub 2, 2ac and 3 all without issues before this one.
Also for some additional information - my hub is FW version 01.02.065.21.EURO.PC20. Hardware version 11.
Hoping someone might be able to help provide advice/tips before I need to send the Hub back
Thank you
Chris
