LawBax
  • 12
Message 1 of 25
Hub4 Hub or Router Mode? - Connected to external Router/WiFi 1GB supplying at 200MB
Hi, Can anybody help me?
Should the Hub4 be in Hub or Router mode??  if I want to connect to an external Wireless Router TPLink Archer AX50. Previously on Hub3,  I would always of switch to HUB mode but if you turn off WiFi on Hub4 it works ok from any of the ports 1 - 4 (either Hub or Router Mode)
The more important thing the performance is very poor 200 - 500MB  Maybe I should have stuck with the HUB3.  Can anybody advise? I happy to bond to ports and create a trunk link if I have to do this.
LawBax_1-1610739012799.pngLawBax_2-1610739077683.pngLawBax_3-1610739150998.pngLawBax_4-1610739189622.pngLawBax_5-1610739229702.pngLawBax_6-1610739271015.png
carl_pearce
  • 4.75K
  • 405
  • 713
Superstar
Message 2 of 25
Re: Hub4 Hub or Router Mode? - Connected to external Router/WiFi 1GB supplying at 200MB
100% modem mode.
gary_dexter
  • 29.24K
  • 1.8K
  • 3.83K
Message 3 of 25
However your DOCSIS 3.1 channel is only on QAM1024 and should be on QAM4096
carl_pearce
  • 4.75K
  • 405
  • 713
Superstar
Message 4 of 25
@carl_pearce wrote:
100% modem mode.
Just at add to this of the screenshots I can see:
  • One upstream channel is out of spec on QAM.
  • The QAM level is less than 'normal' on the DOCSIS 3.1 channel (I've been corrected on this previously that it 'shouldn't' make a difference).
LawBax
  • 12
Message 5 of 25
Thanks, I have now changed to router mode - Speed is 151Mb
Something very wrong
carl_pearce
  • 4.75K
  • 405
  • 713
Superstar
Message 6 of 25
See above post.
VM need to investigate further.
Create a BQM and post the live link.
LawBax
  • 12
Message 7 of 25
How do I change the QAM values
carl_pearce
  • 4.75K
  • 405
  • 713
Superstar
Message 8 of 25
You can't.
gary_dexter
  • 29.24K
  • 1.8K
  • 3.83K
Message 9 of 25
You don’t. An engineer does.
  • 20.83K
  • 2.22K
  • 3.69K
Message 10 of 25
Is that 151 on wifi or on an ethernet connection? If wifi - try it on a Cat5e or better cable and see what it gets from the router and also direct into the Hub
