SH3user
  • 240
  • 6
  • 43
Superfast
Message 1 of 13
Hub4 Dropouts
I have been running a Hub3 in modem mode with an ASUS RT-AC3200 router for years without issue. Since I replaced the Hub3 with a Hub4 I am getting multiple drop outs every day which is a big problem as I am working from home. I have checked the leads, connections etc and can not identify an issue in the router/Hub4 logs. The Hub4 always has a constant white light during the outages. The only thing that has changed at this end is a Hub4. Could anyone help me to identify the issue so I can contact VM about the problem to save me having to reboot the equipment to get back online. I also thought that the hub4 operated on DOCSIS 3.1 channels mine are zero with DOCSIS 3.0 32 upstream and 4 downstream channels.
lotharmat
  • 2.54K
  • 189
  • 461
Trouble shooter
Message 2 of 13
Re: Hub4 Dropouts
Can you post your Hub status and logs?
Someone should be spot if there is a problem
Navigate to http://192.168.0.1 (or http://192.168.100.1 - if in modem mode)
Don't log in!
Click on 'router status'
Copy/paste the data from each of the tabs. The forum software will remove the MAC addresses for you (you may need to click the 'post' button again).
Also, set up a 'Broadband Quality Monitor'. This will monitor the state of your connection and record any network dropouts etc - You can do this at ThinkBroadband (https://www.thinkbroadband.com/broadband/monitoring/quality)
Give it a while to gather data and then click 'Share Live graph' and paste the 'Direct Link' into the forum!
SH3user
  • 240
  • 6
  • 43
Superfast
Message 3 of 13
Re: Hub4 Dropouts
Sun 06/06/2021 21:12:58
3
No Ranging Response received - T3 time-out;CM-MAC=xx;CMTS-MAC=xx;CM-QOS=1.1;CM-VER=3.1;
Sun 06/06/2021 21:46:28
5
RNG-RSP CCAP Commanded Power Exceeds Value Corresponding to the Top of the DRW;CM-MAC=xx;CMTS-MAC=xx;CM-QOS=1.1;CM-VER=3.1;
Mon 07/06/2021 04:23:38
5
MIMO Event MIMO: Stored MIMO=-1 post cfg file MIMO=-1;CM-MAC=xx;CMTS-MAC=xx;CM-QOS=1.1;CM-VER=3.1;
Mon 07/06/2021 04:24:27
5
Mon 07/06/2021 08:16:19
5
Wed 09/06/2021 22:54:51
5
Thu 10/06/2021 03:58:59
5
Fri 11/06/2021 21:57:18
5
Sat 12/06/2021 04:26:59
5
Mon 14/06/2021 19:55:56
5
Tue 15/06/2021 06:15:15
5
Tue 15/06/2021 18:39:34
5
Wed 16/06/2021 05:57:39
5
SH3user
  • 240
  • 6
  • 43
Superfast
Message 4 of 13
Re: Hub4 Dropouts
3.0 Upstream channels
1 39400000 44.3 5120 KSym/sec 64QAM 4
2 46200000 44 5120 KSym/sec 64QAM 3
3 53700000 44.3 5120 KSym/sec 64QAM 2
4 60300000 44.8 5120 KSym/sec 64QAM 1
1 US_TYPE_STDMA 0 0 0 0
2 US_TYPE_STDMA 0 0 0 0
3 US_TYPE_STDMA 0 0 0 0
4 US_TYPE_STDMA 0 0 0 0
SH3user
  • 240
  • 6
  • 43
Superfast
Message 5 of 13
Re: Hub4 Dropouts
Refresh data
3.0 Downstream channels
5 171000000 9.8 40.9 QAM256 5
1 139000000 9.6 40.9 QAM256 1
2 147000000 10.2 40.4 QAM256 2
3 155000000 10.2 40.9 QAM256 3
4 163000000 10.1 40.4 QAM256 4
6 179000000 9.5 40.4 QAM256 6
7 187000000 9.4 40.9 QAM256 7
8 195000000 9.4 40.9 QAM256 8
9 203000000 9.4 40.9 QAM256 9
10 211000000 9.2 40.4 QAM256 10
11 219000000 9.1 40.4 QAM256 11
12 227000000 9.1 40.9 QAM256 12
13 235000000 9.2 40.9 QAM256 13
14 243000000 9 40.9 QAM256 14
15 251000000 9.1 40.9 QAM256 15
16 259000000 8.9 40.9 QAM256 16
17 267000000 9.2 40.9 QAM256 17
18 275000000 9.6 40.9 QAM256 18
19 283000000 9.5 40.9 QAM256 19
20 291000000 9.3 40.4 QAM256 20
21 299000000 9 40.4 QAM256 21
22 307000000 9.1 40.9 QAM256 22
23 315000000 9.4 40.9 QAM256 23
24 323000000 9.4 40.9 QAM256 24
26 371000000 9 40.4 QAM256 26
30 403000000 8.8 40.9 QAM256 30
31 411000000 8.7 40.9 QAM256 31
34 435000000 8.8 40.4 QAM256 34
36 451000000 9 40.9 QAM256 36
38 467000000 9.2 40.9 QAM256 38
39 475000000 9 40.9 QAM256 39
40 483000000 9.1 40.9 QAM256 40
5 Locked 40.946209 0 0
1 Locked 40.946209 0 0
2 Locked 40.366287 0 0
3 Locked 40.946209 0 0
4 Locked 40.366287 0 0
6 Locked 40.366287 0 0
7 Locked 40.946209 0 0
8 Locked 40.946209 0 0
9 Locked 40.946209 0 0
10 Locked 40.366287 0 0
11 Locked 40.366287 0 0
12 Locked 40.946209 0 0
13 Locked 40.946209 0 0
14 Locked 40.946209 0 0
15 Locked 40.946209 0 0
16 Locked 40.946209 0 0
17 Locked 40.946209 0 0
18 Locked 40.946209 0 0
19 Locked 40.946209 0 0
20 Locked 40.366287 0 0
21 Locked 40.366287 0 0
22 Locked 40.946209 0 0
23 Locked 40.946209 0 0
24 Locked 40.946209 0 0
26 Locked 40.366287 0 0
30 Locked 40.946209 0 0
31 Locked 40.946209 0 0
34 Locked 40.366287 0 0
36 Locked 40.946209 0 0
38 Locked 40.946209 0 0
39 Locked 40.946209 0 0
40 Locked 40.946209 0 0
lotharmat
  • 2.54K
  • 189
  • 461
Trouble shooter
Message 6 of 13
Re: Hub4 Dropouts
DOwnstream power looks to be a little on the high side with a couple over the max of 10!
SH3user
  • 240
  • 6
  • 43
Superfast
Message 7 of 13
Re: Hub4 Dropouts
Thank you for your reply lotharmat. I will set up a monitor as you suggested.
SH3user
  • 240
  • 6
  • 43
Superfast
Message 8 of 13
Re: Hub4 Dropouts
I am close to the VM distribution cabinet and an inline attenuator was fitted during the Hub3 installation.
lotharmat
  • 2.54K
  • 189
  • 461
Trouble shooter
Message 9 of 13
Re: Hub4 Dropouts
Like Jaws - I think we're gonna need a bigger attenuator!!
SH3user
  • 240
  • 6
  • 43
Superfast
Message 10 of 13
Re: Hub4 Dropouts
I can't remember how many db the existing one is so I will check and contact VM for another and let you know the result. Thank you for your help today lotharmat.
