Hub3s own MAC Addresses
Hello, can anyone can tell how many MAC addresses a Hub3 has please? On the Admin/Info tab I can see a Cable MAC address, and a very similar WAN IP MAC address - could there be a third MAC address associated with the Hub itself? I am asking because we have a WIFI MESH attached to the router, and its showing an unrecognised offline device with an almost identical MAC address to the Hub3s Cable/WAN, only one digit is different in the final pair - it seems too much of a coincidence not to be related to the Router, but I dont know how to check Thanks!
  • 7.42K
  • 254
  • 1.77K
Community Lead
Community Lead
Re: Hub3s own MAC Addresses
Hi rupertgiles,
There are generally two MAC addresses associated with the hub. There's a CM MAC, which is printed on the bottom and identifies the equipment on our network - that's how we ensure the correct equipment is set up on accounts etc. The hub also has a CPE MAC address, which is probably the 2nd one you're seeing, this is usually very similar to the CM MAC with just the last digit being different.
Kev
