Andrzej1
Hub3
Hello, the green light is blinking very often in hub 3 virgin
lotharmat
  • 966
  • 71
  • 145
Well-informed
Re: Hub3
Can you try a pin-hole reset?
Unplug all ethernet cables
With the power on and the co-ax connected; press and hold the reset switch with a paperclip or sim removal tool for at least 60 seconds.
Allow 10 minutes to reboot, reset and stabilise
If the green light is still flashing then VM staff need to take a look and diagnose!
Beth_G
  • 3.16K
  • 199
  • 312
Re: Hub3
Hi Andrzej1,
Welcome to the Community Forums, thanks for your post.
I'm sorry to hear you're having a few issues with your broadband service - can you please confirm which lights exactly are flashing green?
I've been able to find your account and everything looks OK from here. Were you able to follow lotharmat's advice and check all your connections? If you are still seeking help just give us a shout.
Beth
