  • 6
Hub3 won't factory reset to router mode
I can't get my Hub3 out of modem mode. When I factory reset it, it just restarts in modem mode and not router mode.
Tags (1)
  • 6
Can't get Hub3 back to router mode
My WiFi has been dropping out every 5 minutes or so then reconnecting. I decided to try putting it in modern mode and using my TP-Link Archer VR2800 as a WiFi router. Put the Hub3 into modern mode. Tried to get the router working, but couldn't. Decided I've bitten off more than I can chew, so thought I'd just factory reset the Hub3 and it would go back to router mode, but it won't. It resets beck to modern mode and I don't know how to change it back.
Please help, I'm desperate, I have an exam that I have to take from home!
Tags (2)
  • 11.36K
  • 888
  • 1.45K
Re: Hub3 won't factory reset to router mode
Carry out a factory reset on the Hub using this method …
DO NOT DO THIS if the password on the base of the Hub is not legible or missing.
Instructions for Hub 3
Disconnect all unneeded ethernet cables from the rear of the Hub.
With the Hub Powered on use a paperclip or similar (I use a mobile phone SIM Slot tool) and do a pinhole reset.
DO NOT reboot the hub but allow it 5 to 10 minutes for it to boot itself up.
Once a steady white and no other lights are illuminated check your system again.
Mike Robinson
Retired Aircraft Engineer & Computer Based Training and Learning Designer for many of the world's Military Arms.
  • 11.36K
  • 888
  • 1.45K
Re: Can't get Hub3 back to router mode
Please stick to one thread.
Mike Robinson
  • 6
Cheers... sorted it!
I can stop having a heart attack now!
  • 24.31K
  • 1.39K
  • 3.09K
Go to 192.168.100.1 in a browser and login to the admin page to change it back.
