Message 1 of 7
Hub3 to Netgear AC1900
Upgraded to the Hub3- big mistake.
WiFi was utter trash, so, followed advice on here and switched the H3 to modem mode and direct connected to the Netgear ac1900 for WiFi and a few wired connections (TV/xbox etc).
Problem - the netgear is sending the keep alive message back to the H3, gets nothing back, so then goes into panic and we lose WiFi - any suggestions on the solution?
Mike
  • 30.43K
  • 1.53K
  • 5.29K
Message 2 of 7
Re: Hub3 to Netgear AC1900
what do you mean by "keep alive"
  • 21
Message 3 of 7
if you have switched the Hub 3 to Modem Mode it would suggest the problem lies with the Netgear if WIFI drops. Do wired connections remain active and able to access the internet
Message 4 of 7
Thanks for responding, no, even the wired devices show no Internet.
Screenshot below, its looking to renew DHCP with the netgear, gets no response so closes the connection?
  • 20.96K
  • 1.14K
  • 2.7K
Message 5 of 7
Have you set it up in the correct order?
Are any other devices plugged into the virgin hub Ethernet ports?
Message 6 of 7
 this is what I see based on router log info
  • 1.46K
  • 80
  • 117
Message 7 of 7
Hi Mike2501,
Thanks for your post and welcome to the community forums. Sorry to hear that you have been having connection issues. I've been doing remote diagnostics on your connection and cannot detect any issues on this side. Can you confirm if when you lose connection, does the lights change on the hub?
Cheers,
Corey C
