Hi there @Cardiffman281
Thanks so much for popping back to our Community - sorry that you're having some issues with your HUb3 at the moment.
I have located your account to take a closer look and can see that you last rebooted around 36 hours ago or so. We have no known area issues listed now or in the last 2 weeks for this issue; there are no errors showing and all signal levels are looking to be where we would expect them to be for your package and equipment.
You are correct - the Red power light on usually does mean that the Hub is overheating but we see no evidence of that at this end currently.
The only possible issues we can see is that the 2.4Ghz frequency seems to be rather overloaded with devices. Some devices are also a bit too far away from the hub which is straining the bandwidth a little bit.
If you are seeing some connection drop outs, it may be helpful to set up a free “Broadband Quality Monitor” to continually monitor the state of your connection and record any network dropouts. It does it 24/7/365 and it keeps a visual record of your connection. If you need any help with that please let us know.
Cheers
