Hub3 issues connecting
My superhub 3 restarted itself about 3 hours ago now and since then has been alternating between these two combinations of lights on the display
Solid green base light + flashing green internet light .
flashing green base light only.
I have tried to reset it with the button on the back a couple of times it just keeps going into this state.
Does anyone know any way to get it to connect again? I've checked all connections they're all visibly fine and tight
  • 12.28K
  • 950
  • 1.58K
Re: Hub3 issues connecting
If nothing is showing try phoning 0800 561 0061, this will tell you of more local issues that may be affecting your district. Be aware that it isn't a manned line.
Mike Robinson
Both of those say that there is no issues affecting area currently.
  • 12.28K
  • 950
  • 1.58K
Try a reboot using this method ...
Switch the Hub off using the small switch on the rear of the Hub next to the power cord and pull the PSU plug from the wall socket.
Give it a good 5 minutes put the plug back in and switch the Hub back on.
Allow the Hub a few minutes to fully restart then try your connection again.
Mike Robinson
I had already turned it off for a while earlier between reboots sorry for not mentioning that part. I had it completely disconnected from power source earlier for about 25 mins came back turned it on and it's still the same
  • 801
  • 39
  • 62
Hi there @Stephen491
Thanks for your post. Apologies for the delay in response and to hear you've been having these issues with your connection. How has it been since?
Let us know and we'll do our best to help.
Hollie - Forum Team
