  • 46
Message 1 of 35
Hub3 Speed VERY slow
Background: I started off with an M50 but then out of the blue got an upgrade to a M100 upgrade (same box)
All seemed fine. After getting my V6 (I know it doesn’t connect directly to the interwebzt, so let’s leave the V6 out of this)
Being bored I ran 7-8 speed tests on the M100. The upload hovered around the mid 30’s – so no big issue there, but the download barely made it past 130Mbs (sometimes just 99Mbs) which according to the Virgin site should have been closer to almost 3 times that. (this was a 04:30 in the morning, so not peak times.
Switched everything off for hours, booted up fine, but the speeds were still poor. As I originally found out with my free upgrade was that this is something, they have to deal with at VM, not me at home. Also knowing computing, it would be a 5 min job at best.
Due to COVID-19, support is pretty much no-existent, they didn’t even tell their engineer that after 6 attempts and a text to confirm the cancellation, did they bother to tell him (he was either very polite and/or used to it)? F*ck NO!
Where would you suggest I take my query from here? And trust me I am not going on hold to get hung-up after 2+ hours.
Large companies must be loving this virus, so much work and wages to save.
Tags (1)
  • 25.12K
  • 1.44K
  • 3.2K
Message 2 of 35
Re: Hub3 Speed VERY slow
If you upgraded to M100 then a speed of 99-130Mbps is within that "M100" speed range...?
  • 46
Message 3 of 35
But a M350 connection should replect 350 approx. What would give you the incentive to upgrade?
  • 17.57K
  • 1.85K
  • 3.06K
Message 4 of 35
If you are paying for the 100Mbps service and that's what you are getting. If you want 350 you need to upgrade again, pay more and they will reconfigure your Hub to allow the faster speeds through. Or send you a new Hub if you have an older Superhub.
  • 46
Message 5 of 35
Thanks, willk all due respect, the V6 is nothing more than a shop and a M100 hub with a HDD. I believe I am easily within my legal rights to cancel.
The Virgon Speed Page, plainly states the speeds of a M350 connection.
Possibly my last post.
  • 25.12K
  • 1.44K
  • 3.2K
Message 6 of 35
I don't understand what you're saying.
Do you have a 100Mbps broadband connection or a 350Mbps connection?
  • 12.25K
  • 948
  • 1.57K
Message 7 of 35
Can you please
Copy and paste the contents of the Configuration tab onto here, if you get a yellow / straw box warning click the Post button again. Use one post for each tab if you wish. Please do not use screen grabs.
Mike Robinson
  • 46
Message 8 of 35
Hi, I beleived that my extra (substantial cash) was to upgrade from a M100 to a M350.
Along side that I got a V6 box (which can't connect to the interwebz on it's own, it needs the M100 It is nothing nore than a glorified M100 with more storage. Oh and you have to subscribe to everything. The M100 has Netflix, Amazon Prime etc and even chanels I can't access on the V6 but I can on the M100!
The V6 is just a con, built around sellling more packages and your friends for cash. Plus you have tice as many devices and cables in your house.
  • 46
Message 9 of 35
EDIT:- My contract states (and I quote) - ""
  • 25.12K
  • 1.44K
  • 3.2K
Message 10 of 35
Nothing is a con - if you don't like it, don't buy/subscribe/use it...
You obviously thought wrong about the speeds - what does the contract say that you were sent when signing up for the V6 box?
