AndyH001
Message 1 of 11
Hub3 DHCP
My Hub 3 has DHCP  for my V6 box preset by myself to 192.168.0.16
When my V6 box powers up, it goes through "Awaiting DHCP"
Then says the address is 192.168.10.108
And therefore does not connect to the other services.....
Is this a problem with the Hub OR the V6 box ????
AndyH
Tags (3)
  • 2.91K
  • 220
  • 622
Trouble shooter
Message 2 of 11
Re: Hub3 DHCP
Did you use a Reserved DHCP IP, or did you just set a static IP?
Roger_Gooner
  • 6.54K
  • 473
  • 1.14K
Legend
Message 3 of 11
Re: Hub3 DHCP
I see no reason why any TV box should have a static IP address, so put it back to factory setting and it will get its IP address assigned dynamically.
Hub 3.0, TP-Link Archer C8, TP-Link TL-SG1008D 8-port gigabit switch, V6
AndyH001
Message 4 of 11
Re: Hub3 DHCP
I gave it a reserved address so that it would get a valid one instead of 192,168,10,108 , which is what the DHCP was giving it......Hub 3 is just giving out duff addresses........
Roger_Gooner
  • 6.54K
  • 473
  • 1.14K
Legend
Message 5 of 11
Re: Hub3 DHCP
Why do you think the hub is giving out wrong addresses?
AndyH001
Message 6 of 11
Re: Hub3 DHCP
All of the address's  to ALL of my device's  , V6 box, Laptops,  Network access points ETC. Are ALL wrong......
  • 2.91K
  • 220
  • 622
Trouble shooter
Message 7 of 11
Re: Hub3 DHCP
Are you sure you set the DHCP scope to 192.168.0.xxx? If you have next move would be a full 60 second pinhole reset on the Hub. Do not reboot it, just let it do it’s own thing.
  • 15.93K
  • 687
  • 1.56K
Message 8 of 11
Re: Hub3 DHCP
Do you have HomePlug - Network Via Mains?
sophist
  • 2.18K
  • 375
  • 543
Problem sorter
Message 9 of 11
Re: Hub3 DHCP
It’s either this, and you’re picking up dhcp leases from a neighbours device, or you have another device acting as a dhcp server on your network.
AndyH001
Message 10 of 11
Re: Hub3 DHCP
I had an idea...
Since I could not log into the Hub using 192.168.0.1
I tried 192.168.10.1
This brought up the login page for an access point in my garden....
Turning this OFF and rebooting the Hub sorted the problem with DHCP.
The external access point was a locating the address's. ....
Thanks all
