boroboy2
Message 1 of 9
Hub3.0 red light
There is a red light on my virgin media hub 3.0 as per troubleshooter on site says overheating i have switch off to cool down for several hours done this couple times and still no change also seem to be drop in speeds any help would be appreciated thankyou
Andrew-G
  • 7.47K
  • 1.27K
  • 3.32K
Message 2 of 9
Re: Hub3.0 red light
With the device powered up, use the hole on the back to do a full reset of the device.  Let it come back on line, that sometimes permanently resolves this.  Failing that you'll need a replacement hub.  Let us know how you get on.
Nigel1971
  • 115
  • 6
  • 5
Up to speed
Message 3 of 9
What’s going on lately with loads having red hub light issues? mines ok at the mo.
——————————————— My Broadband Ping - Virgin 500mb Home Connection
boroboy2
Message 4 of 9
red light back on after reset
Andrew-G
  • 7.47K
  • 1.27K
  • 3.32K
Message 5 of 9
No factual idea, but my guess is that there's a small bad batch of Hubs in circulation and they are not ageing well.  Could be something as simple as poor soldering of a heat sensor or the LED, or a dodgy voltage control module, as most of these reports don't seem to be "real" overheating, but if you can't trust the indicator then it's a problem.  Worth remembering that there's around four million Hub 3's in use by VM customers, so the number of reports here are a tiny, tiny fraction of the total.
Of course, those of us running hubs in modem mode would probably never notice a red light, because other than absolutely straight on the magenta looks red.  Given that many hubs are stuffed somewhere inconspicuous, a better overheating indicator would be a piezo bleeper, but that's not the case on any VM hub, and the latest Hub 4 has bizarrely chosen purple....
Andrew-G
  • 7.47K
  • 1.27K
  • 3.32K
Message 6 of 9
@boroboy2 I've flagged this for the forum staff, they'll advise on next steps.  Might take a few hours if their other workloads are full, but its better than risking the telephone "support".
boroboy2
Message 7 of 9
Thanks for your'e help
boroboy2
Message 8 of 9
To be fair had this hub about 5yrs now and no trouble with it till now
Steven_L
  • 5.63K
  • 383
  • 592
Message 9 of 9
Hey@boroboy2,
I can see that you have ordered a new hub and this has now been activated.
Have you had any further issues since the new hub was put into service?
Steven_L
