Hub
My hub switches off on its own accord trying to contact virgin to speak to some one
thanks
Mike
  • 3.57K
  • 196
  • 546
Community elder
Re: Hub
Do you mean it goes completely dead?
Re: Hub
No seems to ne the cable between the transformer and the hub if you move it starts to work again but could be the hub . It has only just to started to do this (last couple of days)
thanks
Mike
  • 2.3K
  • 139
  • 178
Re: Hub
Hi aroofwalker,
Thanks for your post and welcome to the community.
I'm sorry you're having problems with your hub switching itself off.
It really shouldn't be doing that, so we'd need to look in to it. I've also had a look at the backend of your services and I can see that your downstream power levels are out of spec so you'd need a technician visit to get that fixed.
I'll pop you a private message now and we'll get this arranged.
Melissa
