Thanks for popping back @Brirace1
Sorry that you're having some issues still - I have run a few checks from here; can you please reboot the Hub when you have a moment so we can refresh our settings.
We also need you to complete what is called a loopback test to confirm all ports are working on the hub.
To do this, please plug both ends of an Ethernet cable into 2 of the ports on the back of the Hub and confirm that the lights on the ports turn on when the cable is connected.
Please pop back once you have done both those checks and let us know what happens with the loopback test 🙂
Cheers
