  • 43
Dialled in
Message 21 of 34
Re: Hub settings with switch
I know this is probably a stupid question.
I am currently on virgins “up to 100mb” speed range and when running a speed test from my phone I do get 100mb so would there be any real benefit to the router you mention?
  • 2.06K
  • 127
  • 401
Problem sorter
Message 22 of 34
The Hub 3 already is a Gigabit Router, albeit a "built to a price one"... If you are happy with the wifi performance, just buy yourself a decent unmanaged switch for your ethernet cabled kit. You will not max out the Hub 3 with the 100mb package.
  • 43
Dialled in
Message 23 of 34
Would the TP-Link TL-SG1005D be up to it? less then £20 at the mo
  • 2.06K
  • 127
  • 401
Problem sorter
Message 24 of 34
Should be fine. I've a mix of Netgear and TP-Link switches and don't have any problems with either.
  • 10
Message 25 of 34
Those are the TP-Links I have around the house. Ideal bits of kit for simply adding more gig ports.
  • 6.16K
  • 459
  • 1.07K
Hero
Message 26 of 34
The TP-Link TL-SG1005D will provide you with five LAN ports. I don't see the point of this when for £14-£17 you can get the 8-port TP-LINK TL-SG1008D.
Hub 3.0, TP-Link Archer C8, TP-Link TL-SG1008D 8-port gigabit switch, V6
  • 43
Dialled in
Message 27 of 34
Cheers, I thought I would order the 5 port so it would take up less space but checking the measurements the 8 port is still much smaller then the S8000 that I currently have so will order the 8 port instead
  • 43
Dialled in
Message 28 of 34
Has all been running perfectly. Picture quality on UHD streaming better then ever.
Then this evening internet stops completely. Turn hub off/on, around 20 seconds into to restart every light flashes red on the hub for around 2seconds, then back to green, then continues to restart.
stays on okay for a while, then same thing happens?
i don’t remember then hub ever flashing red lights on boot up?
  • 20.96K
  • 1.13K
  • 2.7K
Message 29 of 34
National outage...
As already posted and answered a number of times on here
https://www.virginmedia.com/help/outage
  • 43
Dialled in
Message 30 of 34
Thanks, I thought I had blown up the hub from using all the ports for the first time in ages haha
