  • 43
Dialled in
Message 1 of 34
Hub settings with switch
Hi All,
Looking for some advice, I have a number of devices that I like having connected via ethernet to achieve maximum performance meaning I have had to purchase Netgear Nighthawk S8000 switch for additional ports
Do I need to change the settings within the hub for it to work correctly as I have noticed some issues
I have connected port 1 of the hub to port 8 of the switch as per instructions and then connected the rest into the switch.
I noticed that when streaming a 4K film it constantly buffers but if I connect the ethernet direct to the hub it does not buffer.
Any ideas what would cause this?
(download speeds are pretty stable at 100MB)
  • 20.96K
  • 1.13K
  • 2.7K
Message 2 of 34
Re: Hub settings with switch
No it’s plug and play
  • 6.16K
  • 458
  • 1.07K
Hero
Message 3 of 34
The Netgear is a managed switch which needs a setup. I suspect that this is not what you want, so an unmanaged switch is more suitable. See my sig for an example of such a switch.
Hub 3.0, TP-Link Archer C8, TP-Link TL-SG1008D 8-port gigabit switch, V6
  • 43
Dialled in
Message 4 of 34
That’s quite annoying as the S8000 was relatively expensive in comparison.
Is a managed switch not beneficial? I think I purchased this as I read that QoS function is helpful
At the moment the following need connectivity
xbox one x
panasonic fz802
denon AVR-x3500
virgin v6
hive heating
wifi extender
  • 6.16K
  • 458
  • 1.07K
Hero
Message 5 of 34
Most home setups need an unmanaged switch, just plug and play with nothing to configure or go wrong.
  • 43
Dialled in
Message 6 of 34
Thanks.
I notice you have a Archer C8, is this a router that you use and place the hub into modem mode? Do you see much improvement from this?
I was wondering if I should sell the S8000 and just get a new Router with more ports?
  • 6.16K
  • 458
  • 1.07K
Hero
Message 7 of 34
Yes, I run in modem mode. Most routers have at most four ports, so get a switch. My C8 is a solid mid-range router.
  • 43
Dialled in
Message 8 of 34
As I’m already getting 100MB download speeds would I gain much by purchasing an additional router?
  • 20.96K
  • 1.13K
  • 2.7K
Message 9 of 34
Depends if you want the better wifi coverage and more features in a router such as QOS, VPN, more linear firewall control etc.
  • 43
Dialled in
Message 10 of 34
I thought that’s what the switch would do.
I have connected all back to the switch now and watched a 4K film and seemed “okay” so now I’m not sure what to do 😒
Is it worth keeping all hard wired or should the WiFi be able to provide the same performance
