on 30-11-2023 14:25
The white line at bottom of hub that should be white is bright red? Is this ok?
on 30-11-2023 15:50
Are yiou still connected ? See this
on 30-11-2023 17:25
Thanks for the info. Ours is a 3hub. Having read a few posts regarding this same issue I think we need to try a pin reset.?
on 01-12-2023 08:12
Good morning @FN
The red light could simply be a failing LED.
Please can you do the below and report back;
Let me know if that fixes the red light.
Best wishes
on 07-12-2023 21:10
on 10-12-2023 11:27
Thanks for the update @FN, we would need to bring you in for a private message to discuss this and resolve.
Please look out for the envelope on the top right of your web browser or if you are using a mobile device, it will be located under your profile icon.
Thanks.
Sabrina
