  • 10
Message 1 of 8
Hub keeps resetting
Hi everyone,
i recently have had an engineer out to look at why my hub keeps resetting, but to no avail. if anything its worse! They replaced some cables and the bit that goes in the wall.
It will reset / restart itself multiple times in a row and can does this for hours on end before stabilising, and will be fine for a while before doing it again.
here is my BQM:
https://www.thinkbroadband.com/broadband/monitoring/quality/share/16e619c0a138e387d717b0aa11c7ae33cb...
I have tried all the usual tricks of resetting, checking connections, checking for local problems via the phoneline, etc
if anyone can help / flag for VM to arrange another  engineer visit i would be very grateful!
  • 24.77K
  • 1.43K
  • 3.15K
Message 2 of 8
Re: Hub keeps resetting
Post the Network, Upstream and Downstream logs from the hubs admin pages please
  • 10
Message 3 of 8
331000000
Locked
Ranged Upstream Channel (Hz)
46200019
Locked
Provisioning State
Online
1331000000-4.240256 qam25
2203000000-540256 qam9
3211000000-5.240256 qam10
4219000000-5.540256 qam11
5227000000-5.440256 qam12
6235000000-5.540256 qam13
7243000000-5.440256 qam14
8251000000-5.540256 qam15
9259000000-5.240256 qam16
10267000000-5.540256 qam17
11275000000-540256 qam18
12283000000-4.940256 qam19
13291000000-4.940256 qam20
14299000000-4.540256 qam21
15307000000-4.540256 qam22
16315000000-4.440256 qam23
17323000000-4.440256 qam24
18371000000-340256 qam26
19379000000-340256 qam27
20387000000-2.940256 qam28
21395000000-2.940256 qam29
22403000000-340256 qam30
23411000000-340256 qam31
24419000000-3.540256 qam32
1Locked40.360
2Locked40.3180
3Locked40.950
4Locked40.960
5Locked40.350
6Locked40.980
7Locked40.350
8Locked40.910
9Locked40.380
10Locked40.310
11Locked40.360
12Locked40.350
13Locked40.340
14Locked40.390
15Locked40.950
16Locked40.360
17Locked40.9160
18Locked40.950
19Locked40.950
20Locked40.350
21Locked40.950
22Locked40.940
23Locked40.940
24Locked40.910
  • 10
Message 4 of 8
1462000194.05512064 qam1
2258000003.9512064 qam4
3326000004.05512064 qam3
4394000004.05512064 qam2
3ATDMA0000
4ATDMA0000
General Configuration
Network access
Allowed
Maximum Number of CPEs
1
Baseline Privacy
Enabled
DOCSIS Mode
Docsis30
Config file
fg87dsfd;kfoA,.iyewrkldJKDHSU
SFID3996
Max Traffic Rate230000061
Max Traffic Burst42600
Min Traffic Rate0
Primary Upstream Service Flow
SFID4355
Max Traffic Rate22000061
Min Traffic Rate0
Max Concatenated Burst42600
Scheduling TypeBestEffort
  • 10
Message 5 of 8
23/10/2020 15:10:29criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
01/01/1970 00:01:45criticalUnicast Maintenance Ranging attempted - No response - Retries exhausted;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
01/01/1970 00:01:45criticalRanging Request Retries exhausted;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
21/10/2020 19:31:58criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
21/10/2020 19:30:15Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
21/10/2020 19:30:13criticalSYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
21/10/2020 19:30:12Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
21/10/2020 19:30:12criticalSYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
21/10/2020 17:14:30Warning!Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
21/10/2020 17:14:27Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
21/10/2020 17:14:25criticalSYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
21/10/2020 17:14:25Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
21/10/2020 13:32:1Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
21/10/2020 13:32:1criticalSYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
21/10/2020 13:32:0Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
21/10/2020 13:32:0criticalSYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
21/10/2020 10:47:52Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
21/10/2020 10:47:52criticalSYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
21/10/2020 10:47:50Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
  • 24.77K
  • 1.43K
  • 3.15K
Message 6 of 8
Your downstream levels are on the low side there - you may need a tech visit to rectify.
  • 10
Message 7 of 8
If anyone reading can help to get me in contact from someone who works for VM, to try and get an engineer out that would be great! 🙂
  • 24.77K
  • 1.43K
  • 3.15K
Message 8 of 8
You can call it in or wait for a forum mod to respond. Response times look to be 5-7 days at the moment.
