on 15-09-2023 14:01
My WiFi signal, generally OK, gets poor at the top and rear of my house. I have tried to use the Connect app to troubleshoot my Hub 3 but the app can't seem to locate the hub... My feeling is that I need WiFi pods to improve this, and so might need a new package and/or maybe a new hub too. But I'm not sure here which is the horse to put before the cart 🤔 In the first instance, can anyone advise on how I can get the Connect app to recognise my hub and test the signal, since the hub is clearly operative hiven all my devices are showing as online...? Thanks!
on 15-09-2023 15:06
Turn OFF all forms of VPNs / Apple Private Relay tools / Android DNS changers and try the VM Connect app again.
If the VM Pods are not free, just buy a Wireless Repeater e.g. an RE450 / AC1750 at least this will be yours and will work with any ISP's Hub / Router.
on 17-09-2023 16:14
Hi @TheUnconsoled 👋.
Thanks for reaching out to us, apologies in the delay in responding to you. Since you have posted this, have you managed to get the issue with the Connect App resolved? If you are still facing signal issues we can assist you here without the app, we would need to bring you in for a private message to discuss this and resolve.
Please look out for the envelope on the top right of your web browser or if you are using a mobile device, it will be located under your profile icon.
Thanks.
Sabrina
