stevemc2
Message 1 of 8
Hub devices
Had a technician out today checking the speed of the broadband as I cant connect remotely for work purposes. He told me there are too many devices connected to the hub ( currently 13 to a hub that only supports a maximum of 10 devices).
How do I go about removing these? does each family individual have to remove the device themselves with their own device  from the virgin network in order for me to be able to log in remotely .
HELP !  : )
Andrew-G
  • 6.92K
  • 1.21K
  • 3.02K
Message 2 of 8
Re: Hub devices
Technician's talking crap.  The hub certainly is a mediocre router, and many of the regulars around here have (like me) bought our own router or mesh wifi setup, but even so it'll support 25 or so devices at least.
  • 23.86K
  • 2.53K
  • 4.33K
Message 3 of 8
Re: Hub devices
Andrew is correct - describe in more detail the issues you are having on wifi and on ethernet connections - how are you trying to connect remotely to work - a VPN?
stevemc2
Message 4 of 8
Re: Hub devices
I think it’s a vpn yes . I have to log in with an Authenticator app and a code . And it keeps timing out now with this error message
stevemc2
Message 5 of 8
Re: Hub devices
How much does the new router or mesh WiFi thing cost and will do the job ? Is that like a booster for the router ? I use my laptop
Andrew-G
  • 6.92K
  • 1.21K
  • 3.02K
Message 6 of 8
Re: Hub devices
Put the wallet on the floor, step away from the wallet with your hands in the air!
If you've got wifi problems a decent router or mesh system is the way to go, but so far we don't know that's your problem.  Unfortunately I can't comment on the VPN aspects, but until somebody can help with that, it may or may not help with your problem.  Since we'd be talking £70-130, probably better to wait than buy in hope?
Yakidd91
  • 15
  • 5
Message 7 of 8
Re: Hub devices
Also worth raising with your works IT Support.
I work in IT myself and believe me when I say VPNs aren't so simple as they seem. More often than they should be able to narrow down where the issue is.
stevemc2
Message 8 of 8
Re: Hub devices
Thank you
