@Peppers wrote:
Thanks for your help/reply.
Yes I have something wired to it that has no issues with connection.
Would a WiFi booster plug be worthwhile? Or what do you recommend?
Cheers
Lee
wifi extenders / powerline adapters are probably the worst option. i wouldn't recommend them.
If you're happy that wired connections work well then i'd consider/recommend a better wireless router or a mesh system - which of these options largely depends on what you want from a device and how much you want to spend..
a good quality router will provide a reliable connection, but there's a limit to how far it will transmit a signal.. mesh systems, at least at the lower end, are more about providing a strong wireless signal to a larger area but at the cost of overall performance.. you can mitigate the performance hit by spending a lot more money.. but that goes back to the budget question..
