Hub Factory Reset
So we've been having awful broadband for a few weeks now. I've tried everything. Since performing a factory reset, we've not lost out 2G & 5G channels.
Does anyone know how to get these back?
Thanks in advance.
  • 14.74K
  • 620
  • 1.42K
Re: Hub Factory Reset
When you had enough of the hub messing you about get your own wireless router with 1Gb ports with the hub in modem mode.
  • 4.39K
  • 744
  • 1.78K
Just one of many possibilities, but go into the hub's settings, see if the wifi networks are turned on, and check the network name.  If before the reset you, somebody else, or even a VM employee had renamed the networks (eg to keep the 2.4 and 5 GHz separate), then the reset will have put it all back to the default, and devices won't recognise the network name.  If that theory is right, you can either rename the networks, or just reconnect devices to the network name currently broadcasting.
  • 3.8K
  • 154
  • 219
Thanks for the post Stevesmithy and welcome to our community.
How are things today?
If still experiencing issues did you try the suggestions above as well?
Let us know, Emily.
Hi.
Its working fine for now. Everytime we have issues, we disconnect the hub, leave it for 10 mins and then start again. It works ok then.
Not ideal but for the timebeing, it works until we find another solution.
  • 3.8K
  • 154
  • 219
Glad to hear you found a resolution for this, do you try a pin hole reset before unplugging?
Thanks, Emily.
