on 27-12-2023 13:58
Hi just got upgraded to 1 gig speed . Currently using hub 4 , but now wifi not as strong , is it better with hub 5 , I need it for my outdoor camera, if I do need hub 5 , would it cost me or would I be a free upgrade ??
Tia
Answered! Go to Answer
on 04-01-2024 12:52
on 27-12-2023 14:20
By accounts on the board the hub5 is not much better for WiFi except having WiFi 6 available, but this would be no use for your outdoor camera as I have never seen a retail one that supports WiFi 6. Best bet for outdoor WiFi is to get a good quality Wireless Access Point. The ones I use give a good signal right to the end of my garden and also it’s good at the front for the car.
on 29-12-2023 15:35
Hello wato500.
Thanks for your post.
Sorry to hear the connection doesn't reach for your camera.
The good news is as you are on our 1gb service I can arrange for a pod to be sent out free of charge.
If you can check the Logo top right of your screen that would be great.
Gareth_L
on 04-01-2024 12:52
Installed hub 5 , and everything is working faultlessly,
