Hub 5
Exo45
Hello my broadband cable doesn’t seem to fit into the hub 5 connecter im not sure if I have been given the wrong cable or not but my phone will not connect to the Wi-Fi although the white light is on and everything else is secured and connected is this a fault on Virgin media’s end or do I need to push the cable in further even tho it doesn’t seem to budge any further than that
3 REPLIES 3
goslow
A dimmed white light shows a normal connection (to the outside world). See below for light options
https://www.virginmedia.com/help/broadband/virgin-media-wifi-not-working
What happens when you connect a device via an ethernet cable (such as a laptop, PC etc.)?
What happens when you try to connect a different wireless device?
You may be experiencing an issue with your phone trying to deal with the Hub 5's wireless AX connection.
Edit: A problem with hub activation is also being discussed here
https://community.virginmedia.com/t5/QuickStart-set-up-and/Hub-5-installed-but-is-not-connecting/td-...
Hi @Exo45
Looking through today's posts it appears that VM activations aren't currently working.
Hopefully the VM systems will kick in fully tomorrow and complete the activation, however if doesn't, then call the activation team on 0800 953 9500 to activate the hub
Dave
The do's and don'ts.
Joseph_B
Hey @Exo45,
Welcome to the Community Forums and thanks for the post.
Sorry to hear you were experiencing this issue setting up your Hub, has this since started working for you as expected?
Joe
