Solid green is modem mode. When in modem mode you need to access the hub on 192.168.100.1.
And when in modem mode, only the first ethernet device recognised will work, so you must have your mesh system as the only device connected by ethernet. Often that means means turning off the hub, unplugging any existing devices, then connect the mesh, then turn on the hub.
