What model and year is the mac and what OS is it on? Are you running any antiviral stuff or QoS package on it ? If so try turning it all off first
Can you do a "pure" speed test like this
________________________________
Connect the Mac, via a NEW and working Cat5e/6a ethernet cable, directly to the Hub (use a RJ45 adapter for what ever port the Mac has). Then put the into “modem mode”
https://www.virginmedia.com/help/virgin-media-hub-modem-mode ).
...or go into the Hub settings and turn off/disable the wifi and also disconnect all ethernet cables from the Hub. This ensures that NO other devices are connected
Test speeds at
https://speedtest.samknows.com/ - or
https://www.speedtest.net/ - try on 2 different browsers - as Chrome sometimes gives odd results.
What does that get
