on 12-10-2023 19:51
Hello
I have been having trouble with my broadband randomly dropping out and the wifi keeps disconnecting and reconnecting on my samsung s23, i've not had this router for long, are there any checks that can be done ?
on 13-10-2023 16:42
Firstly... Can we check… are your issues only evident on wifi connections or do you see them at the same times on devices connected on ethernet cables? If you don't know, can you check to help diagnose whether it is just a wifi issue or it could be network connection/Hub related?
What Hub model is it? What are the various Hub lights showing/doing when this happens if a Hub3 is the base light a steady white(ish) or flashing green?
on 15-10-2023 16:49
Sorry to hear of any broadband issues.
I've not been able to locate you from the forum details provided so gonna drop you a PM now to get them and can run some tests.
Best wishes.
on 15-10-2023 17:04
Settings to discourage mobiles from dropping Wi-Fi and reverting to the GSM mobile data.
For iPhones...
Disable "Wi-Fi Assist" Ref:https://support.apple.com/en-us/102228
For Android phones...
Disable "Switch to mobile data"
Settings >> Connections >> Wi-Fi >> ... ( 3 dot menu ) >> "Switch to mobile data" ( set to OFF )
on 15-10-2023 17:13
Have a pod😖
