Hub 5 from hub 3
TheFatLad
I've recently upgraded from a hub 3 (with no issues) to a hub 5 and 1gig internet. My internet is now worse than it's ever been. My hub 3 was consistently giving me 500mb+ download and 40mb upload ( I was on 600mb broadband).
Now, ever since having the hub 5 I get dropouts daily and inconsistent speed. Ranging from less than 100mb down and 10mb up to 800mb down and 100mb up.
Can anyone help before I spend hours on hold to be told to wait 48hours and then call back as that's what normally happens
TIA
Kieran.
19 REPLIES 19
carl_pearce
Community elder
Does this site, that tests the speed to the HUB over the VM network, show the same inconsistency?
https://samknows.com/realspeed/
Yes. I have done a lot of reading over the last few weeks and I can only guess that it may be cables coming to my home that aren't as good as they used to be. But I thought I'd post to see if I get the same thoughts from others. Here's my test as of right now.
 regards.
carl_pearce
Community elder
Certainly looks like a line fault, or local outage.
Legend
92.6 Mb/s at the device looks like the speed is limited by a 100Mb/s connection.
The all the Downstream channels have very high Post Rs and Uncorrectable error counts.
Did you call 0800 561 0061 to see if there is a known issue in your street.
I have done previously and there's been no maintenance in the area. This has been the same for about 3 weeks now since having the hub 5 in place. I've not had any issues (outside of when there's actual maintanence happening) with my hub 3.
There's some work going on in the area after checking right now. But this has been going on for about 3 weeks and I've checked before and there's been 0 maintanence previously and Virgin are normally pretty quick with works. (at least they are in previous times by me) it just seems weird that the issues have only risen since having the hub 5
TheFatLad
Also, not sure if this helps but I can't put a BQM on my line as it completely drops my internet out. Also, if i run a speed test that can also have the same affect and the router loses connection for about 30 seconds.
TheFatLad
This is the latest log.
Reece_MH
Hi there 👋
Thanks for posting, and welcome to the Community Forums.
I'm sorry to hear you're experiencing some issues with your service. I've taken a look on our side and can see there is currently a known problem in your area. The details are below.
Fault Type: SNR (Signal-To-Noise)
Fault Reference: F011017740
Estimated Fix Time: 26 OCT 2023 09:00
Our teams are working as quickly as possible to resolve this issue, and we're very sorry for any inconvenience caused.
Regards,
Reece - Forum Team
New around here? To find out more about the Community check out our FAQ
