on 29-12-2022 22:42
Hi all,
My hub is flashing a red light, but I have checked all the wires and all are connected securely. I called 150 and there is a service fault in my area, but I would like to know if it is normal for the hub to be flashing a red light due to service fault. Or is the flashing red light due to a faulty area. I can't really identify the problem because my computer is able to connect to the wifi, but there is no internet.
Thank you!
on 29-12-2022 23:18
Red flashing LED means the hub has lost connection with the VM network. It normally is not a hub problem, but a VM cable/cab/network problem.
Keep phoning Area faults on 0800 561 0061 If you have a VM landline 150 this goes down to post code level. You could also try the web page status, but this is not recommended as it only covers issues that affect a very large number of customers.
on 29-12-2022 23:33
Is it likely that the problem is due to the fact that service around my area is disrupted? Cause my cables are all connected and fine....
on 02-01-2023 09:27
Hi mtyt
I am sorry to hear of any broadband issues - normally the red light on the hub means an issue with the network - https://www.virginmedia.com/help/broadband/virgin-media-wifi-not-working
Have you checked the faults line to get the estimated fix date/time?
Best,
