simbobrady
Message 1 of 7
Hub 5 flashing blue light
Had my Internet completely drop. My router has a flashing blue light. I have attempted  to reset and hard reset which has failed, still got flashing blue lights  with no Internet.
Luxoflux
  • 6
Message 2 of 7
Re: Hub 5 flashing blue light
Same problem, Virgin trial in the WF4 area.
  • 6.79K
  • 591
  • 1.78K
Message 3 of 7
Try checking with Area faults on 0800 561 0061 or if you have a VM landline 150 as small local faults are not listed on the VM status page.
simbobrady
Message 4 of 7
Hi thanks for the tip. Unfortunately no issues with broadband in my area according to this
eateggs
Message 5 of 7
I'm in s72 postcode area s hiendley just down the road mines gone off as well on the trial tried ringing virgin gave up on them,
Keltosh
  • 30
  • 5
Message 6 of 7
Yes we are the same, internet disconnected , tried hub 5 reset but blue light on the hub flashing. Area 14
BD20.
Regards.
Ayisha_B
  • 4.46K
  • 174
  • 395
Message 7 of 7
Hi @simbobrady 👋,
Welcome to our Community Forums and thanks for your post.
I am sorry for any issues with your service.
Checking our systems, I can see you were impacted by an area outage but this has been verified as resolved.
Let me know if you still have any problems.
Ayisha_B
