Hub 5 fail
Gypsycat
I've just upgraded to the Hub 5 from the Hub 3. It arrived last Tues and I've had nothing but problems since. The internet keeps dropping. The TV seems to be fine but it's not working so well on our 2 phones. Sites won't load. An engineer came out on Friday and fitted a splitter but it doesn't seem to have made any difference. At the moment I'm wishing I had my 3 back but I've already returned it 😕 Any advice?
1 ACCEPTED SOLUTION
Accepted Solutions
Roger_Gooner
Ignore the warnings and keep pasting.
Hub 5, TP-Link TL-SG108S 8-port gigabit switch, 360
My Broadband Ping - Roger's VM hub 5 broadband connection
10 REPLIES 10
Roger_Gooner
Can you post some stats. Go to 192.168.0.1 (router mode) or 192.168.100.1 (modem mode), do not log in, click on the link "Check Router Status". Copy and paste the Downstream, Upstream and Network Logs as text (not images). Mask any public IP address.
  3310000002.539QAM 25625
  21390000003.737QAM 2561
  31470000003.337QAM 2562
  41550000003.437QAM 2563
  51630000003.237QAM 2564
  61710000002.637QAM 2565
  71790000002.837QAM 2566
  81870000002.937QAM 2567
  91950000002.838QAM 2568
  102030000002.638QAM 2569
  112110000002.937QAM 25610
  122190000002.438QAM 25611
  132270000001.937QAM 25612
  142350000002.238QAM 25613
  152430000001.938QAM 25614
  162510000001.538QAM 25615
  172590000001.738QAM 25616
This is taking ages cos it keeps cutting out
It wouldn't allow me to copy and paste any more on here. Kept coming up with a warning and incorrect html notices. I don't understand what I'm looking at. The network log had a lot of 'warning' and 'notice' in the priority column if that helps at all.
LASPPT
The same has been happening to me for the last month, and since I moved to the new Hub 5 and the 1GB connection. It’s been appalling.
Roger_Gooner
Still not letting me do it. I've got an engineer coming on Tues now but can I just get my Hub 3 back? The Hub 5 really is a massive fail so far!
avi68
Up to speed
I’m having similar issues. Had a hub 4 before and that was giving me issues. They thought it was the hub so they replaced with a hub 5 and it’s been really bad. I never had the internet disconnect but now with the hub 5 I get regular disconnection. I always leave my hubs in modem mode. I’m going to follow this thread.
Pilzo
Good luck to you chaps about getting this fixed. I have the 1gb hub 5 constant high pings when gaming. I am still trying after 5 months for a fix. All they want to do is cancel my contract over 30 days and not fix the issues. If I were you, cancel Virgin Media, and go somewhere else. Unfortunately, I cannot as it's low bit rate copper to my house.
